Idea for changing case colour
Go to solution Solved by W-L,
5 minutes ago, Gnomo said:
Hey
I have an idea and that is once again something strange.
I have a black phanteks enthoo luxe here and I want to know if you know a good way to get the whole inside white and the outside stays black. A white case is also not what I am looking for because I want the outside all black and the inside all white. If you have any good idea, I will gladly take it but this would be the first idea of the case that I am thinking of in my head.
Normal paint? Any heat resistant paint needed? What kind of preparation I need before coloring it and how good will white work on black?
Thanks for helping a beginner in casemods.
For the best results you will need to take apart the case for painting the interior sections like the motherboard tray, and it will not require any special paint as it doesn't get anywhere near hot enough to cause a problem. Some of the best stuff out there is usually automotive stuff where they have more vibrant colors and options. For prep and such I have a guide here on General Painting that will go over all of that:
Hey
https://linustechtips.com/topic/728238-idea-for-changing-case-colour/
Hey
Thanks, that looks really nice. One question because I just saw it in the guide. Could I also simply just vinyl wrap my pc inside?
But I will look into the complete guide, this seems pretty much to be what I am looking for to do my dream pc.
When I have an idea of how it works and what needs to be done I can either find a place where I can do it or someone who does it for some money (e.g. vinyl shop)
It's possible but may be quite complex due to the interior corners and such as it needs to be cut oversized then trimmed exactly to size after installation.
On 1/27/2017 at 9:03 PM, Gnomo said:
What kind of shop does powder-coat jobs? Automotive?
lol honestly i dont know, auto shops are probably not likely, a web search brings up 4 powder coaters in Austria, looks like theres one right off the B1 in Puhret, called "dr. tech powder" but im an american giving an Austrian directions to a place in Austria so who knows how well that will work out .. also a business directory should have better info than i can give you
