So I recently bought an Emtec micro SD card, which came with an SD adapter. Upon unboxing the card and plugging it into my desktop's SD card reader on the front panel, nothing happened. Fearing the card was a dud, I plugged it into my laptop, where it worked perfectly. So I went online, absolutely no help whatsoever. Then I remembered that I had a Sony multi-card reader that I use to get pictures off my camera's CF cards which also had an SD card reader slot on it. Plugged the Sony reader into my laptop and the SD card into, no problems. Then upon trying the Sony reader on my desktop, it worked... I tried again in the computer's native reader, but it still was not detected, no Windows beep, back into the Sony reader, perfect. WTF. Was waiting for help, but then I realized: I PLUGGED IT WRONG. I hate myself now, HOW DID I NOT NOTICE THAT, WTF. Anyways, I'm dumb, I don't need help
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/727656-sd-card-reader-problems/
