Help with bios
Go to solution Solved by Bwithnewcast,
22 hours ago, exercutor5 said:
So what if it is a laptop? If you don't want to take our advice of resetting the BIOS by removing the CMOS battery, then good luck with what you want to do with it. And even if you need to use the laptop, how long would this process of dismantling and then reassembling even take? Like what, 1 hour tops. You're not gonna be face glued to the screen for 25 hours a day ain't you.
Yes i understand but i was wondering if there was some sort of other way, but yeah i am going to clear cmos
there should always be a cmos battery though. you just have to access the board.
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/727396-help-with-bios/#findComment-9249423
13 hours ago, Bwithnewcast said:
Its not that easy...
Just follow the manual from HP, it will tell you how, even if the CMOS battery is on the other side of the motherboard.
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
https://linustechtips.com/topic/727396-help-with-bios/#findComment-9253449
First of all it is a laptop and second of all i need to use the pc, so dismanteling is not an option
https://linustechtips.com/topic/727396-help-with-bios/#findComment-9256318
https://linustechtips.com/topic/727396-help-with-bios/#findComment-9257636
https://linustechtips.com/topic/727396-help-with-bios/#findComment-9262604
