3D-Printer: KIT or DIY
Solved by dany_boy,
4 hours ago, Akadis said:i am thinking about diy to save money. Would I have disadvantages like bigger tolerances and stuff?
The money you will save is not much, and the disadvantages are many if you go full DIY. Even with a kit a 3d printer can be difficult to set up. Go for a kit if you wanna save money, if you want it to just work buy a pre-made.
Cheers!
