So just now my computers ram has been being filled with java web launcher something and well after about 5-10 minutes after boot it does it again it seems to happen only when I don't go into task manager and end java update manager or whatever is there a way to prevent this?
Please @Dormant God or quote me if you want me to see your message/reply
        Custom PC Specs
Custom PC Build: (CPU) i7-6700k (MotherBoard) GIGABYTE G1.Sniper Z170 SLI ATX (RAM) 16 GB Dual Channel DDR4/3000MHz (GPU) MSI GTX 1080 (Case) Crystal 570X RGB (Storage) 1 TB HDD from Seagate
https://linustechtips.com/topic/727291-i-need-help/
I don't see The Program in Startup
        Custom PC Specs
https://linustechtips.com/topic/727291-i-need-help/#findComment-9250448
