Hey guys,
I was asked by my parents to build them a new PC. I have built my own gaming rig before so I have no problem at all with building it. I just need some help on selecting the parts. There budget for the desktop itself is $500. So far this is what i have come up with in Pcpartspicker. https://pcpartpicker.com/list/9thKkT . It will be used for hobbyist work and general web browsing. First I picked the i3-6100 because its a very powerful dual core with hyperthreading and 4 threads and just using stock cpu cooler. Im also going to get them a SSD because i feel like that is very important to them to have a very responsive and speedy desktop. They dont need much space at all so im going to get only the 250gb version. Im also going to be going micro atx so the desktop is not very noticeable so i went with the cooler master elite 130. Also the PC needs to have WIFI as there is no ethernet. So i selected the Gigabyte-h170n that has built in wifi. Im going to be giving them my old gtx 770 that i have lying around as well because why not. What would you change to this parts list and does it look good?
[CPU: 4.3 GHZ I5-4670K] [MB: Gigabyte Z87-D3H] [RAM: Corsair Vengeance 1833 MHZ (8GB)]
[GPU: Gigabyte G1 Gaming GTX 1070] [PSU: Corsair CX-750] [Cooler: Hyper 212 Evo]
[Storage: 2TB 7200RPM HDD / 500GB Samsung 850 EVO ] [Case: ThermalTake Chaser-MK 1]
[Keyboard:Corsair K70 RGB Cherry MX] [Mouse: Razer DeathAdder] [Monitor: 2 x ASUS 24 INCH IPS (1440p Soon)]
https://linustechtips.com/topic/727161-build-for-parents/
Hi! I recommend a Pentium G4560 because it's got Hyperthreading, so it's in reality an i3 in disguise but costs only $75. Pair it up with a 200-series motherboard.
Also:
Changed the memory to a single 8GB stick so you can upgrade it later.
Changed the SSD to a bigger one.
Made budget room (for the big SSD) by changing the PSU to one that's cheaper. It's still great and fully modular.
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  ($75.00 @ B&H)
Motherboard: Gigabyte GA-H270N-WIFI Mini ITX LGA1151 Motherboard  ($119.99 @ SuperBiiz)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2133 Memory  ($50.98 @ Newegg)
Storage: SK hynix SL308 500GB 2.5" Solid State Drive  ($127.99 @ SuperBiiz)
Case: Cooler Master Elite 130 Mini ITX Tower Case  ($42.99 @ SuperBiiz)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($64.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($18.80 @ OutletPC)
Total: $500.74
Generated by PCPartPicker 2017-01-22 19:17 EST-0500
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/727161-build-for-parents/#findComment-9246605
Also:
Total: $500.74
I like it. Not sure about the SSD tho as I have never heard of it/used it. But everything else looks nice
https://linustechtips.com/topic/727161-build-for-parents/#findComment-9246642
Hynix is a really good brand, but don't go by brand. Take a look at the review.
http://www.tomshardware.com/reviews/sk-hynix-sl308-ssd-review,4583.html
Computer Specs:
https://linustechtips.com/topic/727161-build-for-parents/#findComment-9246656
2 minutes ago, wii8cookies said:
what you could also do for a lot cheaper is just go out and buy a prebuilt for around ~$150, then just replace the HDD with and SSD, and maybe add another 4gb of ram.
That's true there are a couple options for cheaper that would give close to the same performance.
Computer Specs:
https://linustechtips.com/topic/727161-build-for-parents/#findComment-9246703
