dafuq is this formating? fix your post man!
Builds:
https://linustechtips.com/topic/726997-do-i-need-a-water-block/#findComment-9244842
problem is that GPU is not a reference card (OE nVidia PCB), thus no standard waterblock is available at this time.
could use a nzxt g10 to start, but doubtful a block would be made as the 'popularity' just would not be as well as the other designs.
https://linustechtips.com/topic/726997-do-i-need-a-water-block/#findComment-9245049
