So my friend has expressed how she would like me told help her build a form factor pc.  She plans on doing a lot of art on it with her bamboo pad and some animation stuff.  also she was planing top dabel in some games.  I was haveing a hard time trying to find some decent components from components i trust from my some what decent pc building experience.  And one last thing how much do you guys feel like having two drives one SSD for boot programs and a HHD for mas storage is important.  Thanks for the Help
https://linustechtips.com/topic/726985-pc-build-for-friend/
Having a SSD for boot and a HDD for mass storage is fine, lots of people (including me). Also what is the budget?
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/726985-pc-build-for-friend/#findComment-9244721
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/726985-pc-build-for-friend/#findComment-9244817
1 minute ago, hconverse02 said:
Maybe that with a i5 6500 or 7500 and more ssd storage like 240 gb for her main games
Good idea
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/726985-pc-build-for-friend/#findComment-9244831
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/726985-pc-build-for-friend/#findComment-9244832
Id probably go on the route of a non overclockable quad core (like a i5 7400 or 6400) 8-16gb ram since its mini itx i wouldnt overclock, a 1050ti probs, and that phanteks enthoo evolve itx looks cool. 120-240gb boot drive, and 1tb hdd.
P.S Im not responsible for what happens with this build, im just giving suggestions toward your purchase,. I dont know about full compatability.
https://linustechtips.com/topic/726985-pc-build-for-friend/#findComment-9244837
ok and how do you guys feel about how many cores
https://linustechtips.com/topic/726985-pc-build-for-friend/#findComment-9244844
wheres the cpu cooler
What's wrong with stock
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/726985-pc-build-for-friend/#findComment-9244855
4 is enough for gaming.
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/726985-pc-build-for-friend/#findComment-9244862
4 is enough and this https://pcpartpicker.com/list/NKQRCy would do.  If you want to save some money, go for 8 gb of ram.
They would need a previous Skylake to update the BIOS, and 270 motherboards are pricier so I would stick with Skylake.
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/726985-pc-build-for-friend/#findComment-9244870
