So i'm looking to start building a desk that i can put my pc inside of and so i need some help in trying to figure out a couple of things. I will go on by listing them below.
- Water cooling system with reservoirs and added color to the water (pretty much how to go about it and the do's and don'ts).
- A button on the front of the box to adjust lighting in the box as well as a power button that plays a sound when I power up the PC.
- Build the desk so i can stand when I use it, dont wanna be sitting when i use my pc so I  need some idea for making legs that wont wobble being that high but also look a little cooler that four legs on each side.
- Custom Cables(Where to buy, what to look out for)
- Rgb Fans and cables (best bang for the buck)
- And finally I want to theme my build that has something that makes it mt own, and for that i had the idea of either Zelda themed or Star Wars (Dark Side), so any ideas would be helpful on that front.
This is also a great place if you guys want to shoot ideas off me cause anything that you could suggest is all new to me so it'll be fun to see what you all have to suggest.
There could also be a lot of things that across my time doing this build that il need help with like what are the best materials to buy
p.s I already have the PC built in a case right now so this Is kind of a way for me to step it up a notch and transfer it into a desk.
Also just curious if i film my build or document it with pictures and stuff is it possible to get sponsers by hardware companies (not expecting it but hey worth asking)
Thank you for your time everyone hope to hear what you all have to say
https://linustechtips.com/topic/726919-desk-pc-build-help/
