Lens help
Solved by xQubeZx,
Search for a Wide angle and a macro lens. Sounds like that is what you want.
I'm don't know many M4/3 lenses but the Olympus 12mm f/2 seems kinda small and should provide a 24mm equivilent. I also saw a Leica 14mm that seemed kinda small but that would be a 28mm eqivilent.
For Macro the Panasonic 45mm f/2.8 seems relativly sweet.
Now, I don't know id these lenses are comparible, they are m4/3 mount but that Z-Cam looked a bit special. Also, will you be doing video or stills?
