Hello. Recently I bought a computer and I made it. After installing the drivers from the motherboard and graphics card there is a problem. Before installing the image looks normal, but after installing the drivers from AMD image gets poor quality. How can you solve this problem? I installed Windows 10, Windows 8, Windows 7, and the problem is still. In another computer with the same graphics card problem does not occur. Maybe after installing windows I did not do a thing, or not installed a program? Games with steam at start immediately stop working.
Msi h110m - pro-d
Pentium G4400
Toshiba P300 1TB
RX 460 2GB OC from Sapphire
RAM crucial 2x4GB 2133mhz cl15
Antec 500w VP
Windows 7 64bit home premium
Windows is updated. Video link: https://www.youtube.com/watch?v=ZPsBt9onMCY HDMI connection cable is good because I checked. Monitor: Manta 2205. LED monitor from Samsung can not detect the image.
https://linustechtips.com/topic/726601-rx460-drivers-problem/
6 minutes ago, charlesmazurek said:
I set 1920x1080
Windows normally installs the Graphics drivers in Windows 10.
Oops. Nvm. Didn't see you were using Windows 7.
Why are you using Windows 7 anyways? Windows 10 would fix the graphics driver install problems.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/726601-rx460-drivers-problem/#findComment-9241105
2 hours ago, charlesmazurek said:
use because w7 w10 automatically installs drivers for AMD cards, and after their installation image wygkąda worse.
Udostępnij to tłumaczenie
pls remove formatting.
https://linustechtips.com/topic/726601-rx460-drivers-problem/#findComment-9243710
I plugged the new computer via an HDMI cable (cable IS good) do monitor manta LED2205 and wit problems with image quality. Previously, I had connected laptop via VGA do the same monitor and the image was nice. When I connected this laptop via HDMI This do manta rays appeared ten problem working with a computer (laptop also has graphics from AMD). I plugged the laptop VGA do another monitora- samsung T22B300EW and the image of a nice joke, beer when I plugged the HDMI IS ten same problem. When connected via HDMI new computer (with AMD Radeon RX460) do this for ten samsung samsung even can not detect obrazů (When combined with the laptop detect but poor quality). I took out the RX460 oo this computer and installed a go in a different computer, and thus connected the HDMI cable do Samsung t22b300ew. After installing the drivers picture was normal and in this computer which I bought after the installation of drivers picture is not clear
https://linustechtips.com/topic/726601-rx460-drivers-problem/#findComment-9243869
