2 minutes ago, Amilolv said:
Are msi h110 motherboard and corsair ATX 2.31 VS series 550w compatible?
They should be
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/726427-parts-compatibility/#findComment-9239443
10 minutes ago, Amilolv said:
Yea i did already buy it,waiting for parts now, just now watched some videos on youtube and i started to get worry about compatibility...
Firs time building pc so yea.
You could use PCpartpicker.com to check for compatibility easily.
5 minutes ago, Amilolv said:
Any tips on building pc ?
Do i really need gloves because of static electricity?
Not necessarily. You could discharge yourself by plugging your power supply into the wall and touching the fan grille every so often. If you are worried that you might sap something, you could use gloves or an anti-static wrist-strap.
My system:
CPU: i5-6600K <> Mobo: Gigabyte Z270X Ultra Gaming <> Cooling: Noctua NH-D15 <> GPU: Gigabyte GTX 1070 G1 <> SSD: Intel 600p 256Gb
RAM: Corsair Vengeance LPX (16Gb @ 3000Mhz) <> PSU: Seasonic M12II EVO 620W <> Case: Corsair Carbide 400C <> Fans: 6x Bitfenix Spectre
  Monitor: Asus VG248QE <> Mouse: Steelseries Rival 300 <> Keyboard: Gamdias Hermes Ultimate <> Speakers: Logitech Z333
Ok, my cheapo Bitfenix fans are 120mm, all six of them. Are you happy now?
I am not actually Linus...
You can leave my signature now.....
https://linustechtips.com/topic/726427-parts-compatibility/#findComment-9239509
I built my first PC without any gloves on, just shoes. (on a hard floor) Just touch the inside of the case or wherever it isn't painted.
Also another tip is to look up videos build videos where the person is using your case (Check PCPartPicker on youtube, they have a lot of builds)
Edited by QuantumBit
I made a stupid mistake
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/726427-parts-compatibility/#findComment-9239520
