Alright, title gives you the basis of what my problem is... It's time for some details. First off let me say I didn't plan on doing SLI till i got my new monitors this spring but amazon screwed up and sent me 2, I planned on sending one back, then I had a few adult beverages and the thing just seemed to slip into my computer all on it's own.  So I installed it, and it's recognized.  Went into the nividia control panel, made sure "Multi-display/Mixed GPU acceleration" was set to "Single display performance mode" and "Power management mode" was set to "Prefer maximum performance".  Next I set my overclock to match the first GPU and everything ran smoothly....... except for the fact that I only saw a 10% increase in valley benchmark. Also in game seems un-noticeable.
I suppose you will want to know computer specs so here they are,
2xAsus ROG Strix 1070 8gb
1xAsus Maximus Hero VIII Motherboard
1xi7 6700k intel CPU
32 GB Corsair Vengance DDR$
1xCorsair HX850i PSU (I know I went a bit overkill but I do plan on doing some serious storage upgrades soon)
O.S. Win 8.1 (Side note, I tried it on win 10 and had like a 5% increase first go around)
Standard SLI Bridge
Need to know anything else about computer just ask.
Anyways, I've fiddled around with it. Tried messing with some settings in Nividia inspector for in game performance but what everyone else was setting for there 980's and older for 20-30% increases caused my framerate to drop to 2... yes 2 fps. lol
If anyone can be of assistance I'd appreciate it. I am a bit of a noob so take it easy on me, however I catch on pretty quick so don't be scared to throw ideas at me.,
Thanks in advance,
Rubberburner89
https://linustechtips.com/topic/725741-1070-sli-issue/
Standard SLI Bridge
Thanks in advance,
Rubberburner89
Im not sure if the heaven or valley benchmarks allow SLI support. I know firestrike does, and also, most games dont really support SLI from what i hear. you are better off getting 1 card. so your 2x 1070s, might have been better to get the 1080 since its a single card and less expensive than 2x 1070s. I only ran SLI once, and that was to test 2x 770s vs 1 1070 just to see performance gains.
https://linustechtips.com/topic/725741-1070-sli-issue/#findComment-9232087
Did you enable sli? Also are the device ID the same for both gpu's? When I had two 780 6gb cards they wouldn't sli because they didn't have the same device ID. Not saying this is your issue but it maybe your issue? Maybe one of the sli warriors can chime in with better advice on this.
CPU: 6700K Case: Corsair Air 740 CPU Cooler: H110i GTX Storage: 2x250gb SSD 960gb SSD PSU: Corsair 1200watt GPU: EVGA 1080ti FTW3 RAM: 16gb DDR4
Other Stuffs: Red sleeved cables, White LED lighting 2 noctua fans on cpu cooler and Be Quiet PWM fans on case.
https://linustechtips.com/topic/725741-1070-sli-issue/#findComment-9232088
Standard SLI Bridge
Thanks in advance,
Rubberburner89
I'm not sure if it is correct but I think you need to use the new SLI bridge the High speed (something something) to fully utilize them.
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
https://linustechtips.com/topic/725741-1070-sli-issue/#findComment-9232108
I have two 1080s and your story of how you ended up with SLI is comically similar to my own. That being said, if you're worried about them not being fully utilized, I'd run games with an OSD that shows your GPU usage to make sure it's working properly. Something like Afterburner or Precision XOC should work. You might also try Firestrike or another benchmarking program. As others have said, SLI is pretty hit and miss and depending on the game, you might only get a 10-20% boost. Yes, even with games that say they "support" SLI. I play lots of games and the only title I can think of that has given me 90% + utilization on both cards is The Witcher 3.
https://linustechtips.com/topic/725741-1070-sli-issue/#findComment-9232135
Well... It would appear everything is working properly and my game software hasn't caught up yet...
Honestly I'm not even mad that this game isn't caught up yet. I've been so obbsessed with the low valley benchmarks combined with the poor performance in 1 game that I literally haven't tried any others.  And yes, i did try with and without sli enabled and my score dang near doubled.  So now that I know the hardware isn't messed up I can move on with my life.
I think where I'm on vacation, I may do some day drinking tomorrow to celebrate. :)
https://linustechtips.com/topic/725741-1070-sli-issue/#findComment-9232266
Heaven and valley scale 100% for me. I points and average fps. Games no so much but even so a large increase in frames.
I'd reinstall drivers if you haven't done so already.
Like mentioned you need to watch the stats and ensure both cards are hitting 100% use along with any restrictions.
https://linustechtips.com/topic/725741-1070-sli-issue/#findComment-9232937
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/725741-1070-sli-issue/#findComment-9233020
Quote
I've tried reinstalling drivers literally like 10 times.....  And when I ran valley they we're only averaging about 75% usage, on both cards. Makes no sense to me.
https://linustechtips.com/topic/725741-1070-sli-issue/#findComment-9234452
Then you got problems. What driver version, os, res?
https://linustechtips.com/topic/725741-1070-sli-issue/#findComment-9234662
if you render valley at 1080p on 1070SLI i'm not surprised they aren't maxed out...it's a 4K setup that you have there...
https://linustechtips.com/topic/725741-1070-sli-issue/#findComment-9234671
1 minute ago, rubberburner89 said:
Yeah... I'm running 1080p.... the plan is to this spring get 3 1440p's. Driver vs 376.33 O.S. Win 8.1 (tried win 10 same or worse results)
get a single 3440x1440 Gsync panel istead ;)
https://linustechtips.com/topic/725741-1070-sli-issue/#findComment-9234691
I take it we're done here.
https://linustechtips.com/topic/725741-1070-sli-issue/#findComment-9234769
14 minutes ago, rubberburner89 said:
Yeah... i think so.
If you have that issue with the next monitor then I would worry.  I can't get my old cards to try in games at 1080p.
https://linustechtips.com/topic/725741-1070-sli-issue/#findComment-9234909
