Need a decent PCI-(e) Wireless Card!
lol1419
I'm in the market for a decent pci wireless card because my old one is not cutting it for me (Cisco AM10). Slow reception/ connection etc.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833186012
I don't know the specs of my modem and upon further research I couldn't dig up any results. On that note I don't think my ISP, or modem for that matter, is any thing fancy. (don't believe its dual band or anything like that; just speculation though). Anyways I did my own research and found these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704031&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16833320074
(ignore the "disconnitued" sign; have seen other retailers at selling ~$30)
Not sure if these are good options... wondering for some advice from the community.
If you have any further suggestions please keep it realistic (sub $40). In addition I use my computer for gaming, movie streaming,surfing internet etc. so a good wireless card is necessary.
Thanks in advance,
                      -lol1419
Intel Advanced-N Centrino 6205
The antenna is awesome and Intel's reliable drivers.
If it makes any difference I fount the name of the router:
Sagemcom 2864 VDSL
Will the Intel Advanced-N Centrino 6205 be a good option?
Are the TP-LINK TL-WN951N and  ASUS PCE-N15 any good?
