I am building a PC for gaming and video work and a have decided on a build
(based on recommendations locally )
Processor            - i7 6700K                                             - 1340AED or 365$
Motherboard    - Gigabyte Z170                                 - 585AED or 159$
Ram                       - 8GB DDR 4 HyperX                        - 225AED x 2 or 122$
SSD                        - 1 TB Samsung 850 Evo                 - 1325AED or 361$
HDD                       - 2TB Seagate                                     - 265AED or 73$
Graphic Card      - ASUS 8GB GTX1070                      - 1735AED or 473$
CPU Cooler         - Cooler Master T4 Hyper             - 175AED or 48$
Casing                     -  Gigabyte SUMU                            - 475AED or 130$
Mouse                  - Logitech G402                                 - 185AED or 50$
Monitor               - Samsung LU28E590DS UHD 4K - 1800AED or 490$
I am looking for this level of performance but I have gone a bit over budget.
I need to know if it possible to change the components to reduce the price and keep the performance.
(also pls tell me if I did something wrong)
(Edit)
after listening to you guys suggestions  I am gooing with a 500gb ocz SSD, a 1080p 144hz display and  a 240mm radiator, I will stick with 16gb of RAM and look for a case that's a lot cheaper, I think I'll switch to an ASUS motherboard
so could you help me look for a case(it has to be compatible of course and it must have a side panel window and a reasonable number of fans included)
https://linustechtips.com/topic/725285-pc-newb-looking-for-help/
Change the SSD to a 500GB one, and the 850 EVO tends to be overpriced anyway so look for a different one like a Crucial MX300.
That cooler you chose won't let you overclock much at all. Look for a Cooler Master MasterAir Pro 5, or a Cryorig H7 or H5. That's also a lot of money for a computer case. Should be able to find one for less money.
Also you'll have to turn settings down if you want to play in 4K with a 1070. Should still be playable though.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/725285-pc-newb-looking-for-help/#findComment-9226838
Just now, FTL said:
Please use PcPartPicker. Your post is a mess.
If you find a pcpartpicker version for the United Arab Emirates, sure xD
Computer Specs:
https://linustechtips.com/topic/725285-pc-newb-looking-for-help/#findComment-9226841
1 minute ago, FTL said:
You can use PcPartPicker and change price and currency (i think) manually.
I suppose that's true. The post isn't even that bad though, imo.
Computer Specs:
https://linustechtips.com/topic/725285-pc-newb-looking-for-help/#findComment-9226849
I am looking for this level of performance but i have gone a bit over budget.
In the US there is only a 10$ difference between the 6700k and the 7700k. in most cases I would say upgrading is foolish, but if you're already spending that much, you might as well be on the bleeding edge!
I don't know where you are shopping, but there are GTX1070's available in the US for wayyyy closer to $400. Also you need to add in what kind of gigabyte Z170.
Also I would look into a cheaper air cooler. Not sure what they go for where you are, but they go for $35 here.
i7 4930k \ Asus P9X79 LE \ Corsair H100i \ 16 GB DDR3 G.SKILL Ripjaw \ Asus Strix R9 380x 4GB \ Crucial 500 GB Sata III SSD \ Thermaltake TR2 RX 850W \ Corsair Crystal 460 Black \ Razer Naga Molten edition \ Razer Black Widow Ultimate \ Klipsch Promedia 2.1 speakers \ Hyper X Cloud Alpha \
i5 6600k\ Asus Z170-A \ Corsair H100i v2 \ 16 GB DDR4 G.SKILL Ripjaw \ Asus GTX 1060 6GB 4GB \ SanDisk 480 GB Sata III SSD \ Seasonic G Series550W \ DIYPC Skyline 06 black/green \ Razer Naga Epic \ Razer Black Widow Chroma \ Logitech 2.1 Speakers \ Logitech G430 \
https://linustechtips.com/topic/725285-pc-newb-looking-for-help/#findComment-9226905
