18 minutes ago, AFlyingBuffalo said:
But there's a piece of plastic on the back where I circled on the picture, it prevents even the tiny power plug going though the hole.
but i feel like youre supposed to route the cable through the hole in the front, and down the back opening - with that said it feels a little small for that
you could try prying it gently with a flat screw-driver around all sides  of that plastic piece
Photography / Finance / Gaming
https://linustechtips.com/topic/724979-mg248q-cable-management/#findComment-9223330
I tried routing it through the front but it was even more difficult, ill try prying it off when i get home
https://linustechtips.com/topic/724979-mg248q-cable-management/#findComment-9223348
before you try that consider filing a ticket with asus support and just ask them if this is supposed to come off for cable management
https://linustechtips.com/topic/724979-mg248q-cable-management/#findComment-9223356
  • 11 months later...
