Hey guys iv read on a few sights that it's better to have a high dpi and lower ingame sensitivity
does it mater if I have 400 dpi and 15 sensativety or 800 dpi and 7.5
does having more dpi matter ?
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/724939-sensitivity-vs-raw-dpi/
dpi (dots per inch) is an accuracy measurment.
Lets say you have a dpi of 800. That means that for every inch we move the mouse, we are reading 800 dots. lets say that 2400 dots read = a 180 deg turn in game. if we move our mouse 3 inches on 800 dpi, it will complete the 180 degree turn. if we decrease DPI to 400, we now have to move our mouse 6 inches to make the turn. In my experience, its best to have sensitivity low and DPI as high as possible. I use 400 DPI right now, but for some games a higher dpi is need. 400 DPI is still high enough that it will feel smooth. I wouldnt suggest going below 400 though.
tl;dr - it probably wont matter. 800 dpi 7.5 ig is probably better, but whichever feels better is what you should use.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/724939-sensitivity-vs-raw-dpi/#findComment-9222763
Added you on Overwatch as you requested OP. Anyway, I messed with both settings randomly until I got comfortable with one. I agree it's just a preference thing. A lot of tips say to have low sensitivity and make sure to not rest your mouse hand and float it instead
Intel i7 6700k|Asus Maximus VIII Hero|Asus Strix 1080|Gskill DDR4 3200|950 Pro M.2|Corsair RM750|Corsair OBSIDIAN 500D|Corsair K65\G65|SteelSeries Arctis 5|Asus PB277Q|PG279Q
https://linustechtips.com/topic/724939-sensitivity-vs-raw-dpi/#findComment-9222802
Ok so a higher dpi and lower sensativety doesn't get more accurate reading or anything ?
also (1600)
https://linustechtips.com/topic/724939-sensitivity-vs-raw-dpi/#findComment-9223392
Upon a certain treshold depending on Mouse/Sensor/Firmware the opposite is the case.
https://linustechtips.com/topic/724939-sensitivity-vs-raw-dpi/#findComment-9226901
Iv got a Logitech 502 if that helps
also (1600)
https://linustechtips.com/topic/724939-sensitivity-vs-raw-dpi/#findComment-9227221
