What kind of speed test? Local or over the internet?
Most low end Wi-Fi routers and Wi-Fi receivers will do at least 54Mbps. If your ISP download/upload speed are no higher than 6.75MBps then you'll see no bandwidth difference between copper cable and Wi-Fi or if your Router/receiver & ISP are better than that you'll still see no difference so long as the ISP connection is slower than the local Wi-Fi. It's all about what's the bottleneck.
https://linustechtips.com/topic/724672-problem-with-eithernet/#findComment-9219716
Would help if you include more information .
Is your computer a Laptop or a Desktop ?
What is the speed of the package that you sign up for ?
Do you have a high end wireless card like the Asus PCe AC88 ?
What router are you using ?
What motherboard are you using ?
Is your LAN cable a cat4/5/6/7 ?
https://linustechtips.com/topic/724672-problem-with-eithernet/#findComment-9219743
