So I have a pretty beefy pc and until late just realise it wasnt working at full potential. My friend has a similiar build to mine and always seems to get double my frames no matter what. I need help determining the issue. I planned to do a clean install or reset of windows 10 erasing all my files but i want to do that as a last resort.
My specs:
Intel core i7 6700k
EVGA geforce gtx 1070 SC
8gb vengeance ram
Asus z170-A
1TB hdd
500w (I have no idea if this is the issue, it shouldnt be right?)
Friends specs:
Same CPU
Same GPU
32 gb vengeance ram
Some atx gigabyte board
1 tb hdd
500gb ssd (He has the games on his sdd but that shouldnt increase his frames so much over mine right?)
The last things that could be hurting my system are the psu, ram, or possibly the hard drive(I've tested and it says its healthy).
Wanted to add a few examples: Warface on high, I get 90-100, he gets over 200 easily. Warframe: I get 30 -40fps, he gets over 200 easily.
https://linustechtips.com/topic/724456-i-need-some-help/
What games are you playing?
What EXACT PSU do you have?
What is your CPU/GPU/RAM/VRAM usage when gaming?
What is your CPU/GPU temps when gaming?
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/724456-i-need-some-help/#findComment-9217213
My specs:
Intel core i7 6700k
8gb vengeance ram
Asus z170-A
1TB hdd
Friends specs:
Same CPU
Same GPU
32 gb vengeance ram
1 tb hdd
The SSD will allow assets to be loaded faster, the more ram allows more models to be loaded at a time, the PSU shouldnt be an issue but it might be sending a low ammout of voltage to the CPU which could underclock the CPU though this is unlikely the issue
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
https://linustechtips.com/topic/724456-i-need-some-help/#findComment-9217235
I edited and included some games we both played. he just got a pc so he hasnt bought any games.
I have a EVGA 500w 80+ white? Thats what is says on amazon.
My cpu usage is fine, gpu is fine, ram can get to 70% sometimes, dont know how to check vram but 1070 has 8gb.
My temps are fine. Cpu is liquid cooled and i dont see the gpu go over 70 c very often if at all.
https://linustechtips.com/topic/724456-i-need-some-help/#findComment-9217237
But in games that list that they use only 4gb shouldnt ram not be an issue? I have considered that the motherboard bios could be doing something but i dont know tbh. Its bios are at default like my friends is but we have different brands asus vs. gigabyte in this case
https://linustechtips.com/topic/724456-i-need-some-help/#findComment-9217249
The PSU is just junk, so you should replace that. But it might not be the problem.
Is either your CPU/GPU usage pinned at 100% or are both well below that?
PSU Tier List | CoC
https://linustechtips.com/topic/724456-i-need-some-help/#findComment-9217251
The only thing I can think of is the power supply and memory, the power supply isn't great for a 1070 and 6700k, you might not have enough power going to the cpu or the gpu. Memory is starting to become the minimum of 16GB so more memory may help you in the long run.
lttstore.com
https://linustechtips.com/topic/724456-i-need-some-help/#findComment-9217256
Alright ill hold off on reseting the pc. I was planning on buying this psu in the future. https://www.amazon.com/dp/B01LY4OJYJ/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=26LIGVGJLQQ6K&coliid=I1C05J2QG9YS9S&psc=1 either 750w or 850w. And i want to upgrade ram to 16gb around the same time i upgrade psu.
https://linustechtips.com/topic/724456-i-need-some-help/#findComment-9217268
Any suggestions for psu? I've listed a link to another evga psu above but do they suck?
https://linustechtips.com/topic/724456-i-need-some-help/#findComment-9217278
There is a thing called compression, to allow for more things to be loaded onto lower ammounts of ram, the games will either compress files onto ram and then uncompress them once loaded which can lower FPS. This is why 4GB can be stated as the minimum (Btw this is the ammount of ram required to be free at that time, and with windows taking up to 3 or 4gb now compression is probably occuring)
Plus like I said before the SSD might be the deciding factor as it is wastly faster than the HDD and thus will allow fames to load faster this includes models and other parts of the game like sound.
https://linustechtips.com/topic/724456-i-need-some-help/#findComment-9217280
5 minutes ago, LabRat said:
maybe the in game settings are different between the 2 machines.
what monitors and resolution are the monitors?
don't buy power supplies based on WATTS.
I have a 1080p monitor. Hes playing at 1080p on a 4k at the moment. He plans to get a monitor when he gets payed.
We have our settings maxed.
The psu i listed is G3 and apart of the supernova series as the other user list.
https://linustechtips.com/topic/724456-i-need-some-help/#findComment-9217432
The G3 is a solid choice. Anything from Tier 1-3 (above 400w) from the PSU tier list in my signature will be fine. So buy whatever you're willing to pay for.
PSU Tier List | CoC
https://linustechtips.com/topic/724456-i-need-some-help/#findComment-9217455
