do you use a custom loop with outside winter cooling? mine runs ~40°C with a h100i gtx ( 2x nf f12 ) and ambient temps ~15°C
CPU i7 4790K 4,7Ghz Cooling:Corsair H100iGTX+Noctua NF-F12PWM GPU: EVGA 1080ti SC+ ACX2.0+ RAM:16GB DDR3 1866mhz Crucial Balistics Tactical Tracer Mobo:ASUS Z97-AR PSU:EVGA 750W G2 Supernova Case:Fractal Meshify C Storage:500GB Samsung 850 evo, 900GB Toshiba Game Storage SSD, 2TB Data HDD
i7 4790k Devils Canyon OC @4,6Ghz,Cooler Corsair h100i GTX, GPU EVGA 980Ti SC+ ACX 2.0+ @ stoc
http://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
https://linustechtips.com/topic/724379-are-these-normal-temps/#findComment-9216292
Sounds like your ambient temps are quite low. My temps are the same at idle during winter and around 30 during summer.
CPU - Ryzen Threadripper 2950X | Motherboard - X399 GAMING PRO CARBON AC | RAM - G.Skill Trident Z RGB 4x8GB DDR4-3200 14-13-13-21 | GPU - Aorus GTX 1080 Ti Waterforce WB Xtreme Edition | Case - Inwin 909 (Silver) | Storage - Samsung 950 Pro 500GB, Samsung 970 Evo 500GB, Samsung 840 Evo 500GB, HGST DeskStar 6TB, WD Black 2TB | PSU - Corsair AX1600i | Display - DELL ULTRASHARP U3415W |
https://linustechtips.com/topic/724379-are-these-normal-temps/#findComment-9216307
3 minutes ago, Shadow_Storm56 said:
Either you have a bad sensor or ur pc is in  a room running at 0 to 5c
With a top end air cooler at idle you should be quite close to ambient temperatures on your CPU. That being said I'm on water which pretty much nets me ambient temperatures which are usually 10-12C in winter.
https://linustechtips.com/topic/724379-are-these-normal-temps/#findComment-9216332
At 10 to 12c I'd expect around 20 to 23 idle temps
https://linustechtips.com/topic/724379-are-these-normal-temps/#findComment-9216339
Depends on the cooler and we have no idea what the OP is running. He's from Albania where it's the middle of winter right now so it sounds pretty reasonable to me.
https://linustechtips.com/topic/724379-are-these-normal-temps/#findComment-9216375
