Building first desktop, built system outside of case to check components all worked fine, unfortunately after place the components into the case the green led for power lights up but non of the other components will turn on or light up, I have discharged the power supply and made sure all connections are secure. unsure where to go from there, any help would be great.
System Specs
MotherBoard- ASUS Z170-A
CPU- I5 6600k
CPU Cooler- Cooler Master 212-evo
RAM- Corsair Dominator 16gb (2x8) 3000mhz
HDD- WD Blue 1TB
GPU- ASUS Geforce Dual GTX 1050ti 4gb
PSU- EVGA 500 BQ 80+ Bronze
Thanks again for any help.
https://linustechtips.com/topic/723523-new-builder-need-help/
System Specs
CPU- I5 6600k
HDD- WD Blue 1TB
outside the case you got to the bios?
https://linustechtips.com/topic/723523-new-builder-need-help/#findComment-9206783
1 minute ago, kaisers said:
Yes, I was able to reach bios outside of case.
Does the psu turn on? did your psu come with a tester? something that connects to the motherboard 24 pin to verify it works.
https://linustechtips.com/topic/723523-new-builder-need-help/#findComment-9206790
2 minutes ago, kaisers said:
  Reveal hidden contents
Yes I am using the Q-connector and gone through it 3-4 times checking over making sure all of the connections are correct.
try without the Q-Connector, b/c i was having issues with computer not turning on when using it, so i don't actually use it for mine, just make sure they are lined up correctly
My PCPartPicker - 1st Build
https://linustechtips.com/topic/723523-new-builder-need-help/#findComment-9206843
