Then wait for the TI version, they should be out soon.
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
if looks is a big thing for you then two GTX 760 is a pretty good choice.
My rig : CPU: Intel i7 4820K   Motherboard: Gigabyte GA-X79S-UP5-WIFI   RAM : Kingston hyper X 2133MHz 2x 8GB total 16GB   CPU-Cooling : Corsair H60 V2   SSD : Intel 335 series 180GB   PSU : Corsair RM series 750w   Chassi : Corsair Graphite 600T   GPU : Asus radeon HD7750 ( gonna upgrade soon )
For 2560x1440 an R9 290X would a better choice than the GTX 780.
The higher memory bandwidth will translate into more perofmance and the 4GB of memory will ensure that you don't run out of memory when more demanding titles are released.
I don't recommend the reference R9 290X because it doesn't have much overclocking headroom left in it, so wait for the non-reference cards to pop from Asus, MSI, Gigabyte and the rest of the board partners.
The 780 Ti will be out of your budget.
