led issue
Vinny1216
Have Z170 gigabyte G1 Mobo. system fan 2 and 3 hub have my led strips plugged in however i can only set them to full speed to work( in bios), cant reduce brightness either by going, manual, silent, or normal options. they only turn them off completely.
DL gigabites APP center and was able to reduce the fan curve there, successful in reducing brightness to where i want it, however every time I power the PC back on its back to 100% brightness. and have to set it again. How can I set a more perm. solution for these damn LED's plz?
A fan control thingy 3.5 inch that you can connect the strips to instead and use the knobs to set them at the brightness you want. That shouldn't reset each time you restart. Unless you turn back the knobs that is.
Like this one
Excuse my broken keyboard
CPU - Ryzen 7 2700x
GPU - RX Vega 64
SSD - Samsung 970 M.2 500GB
HDD - WD Black 4TB
Mobo - Asus ROG Strix X470-F Gaming
RAM - 32GB Corsair Vengeance DDR4
PSU - Corsair RM1000x
