Computer blinks red light on case
Solved by STRMfrmXMN,
2 minutes ago, Joseph Hartness said:My case is the v71 thermaltake
Which can be seen by clicking on the name above.
The red light near the circle power button sometimes rarely blinks and sometimes it will blink for a long period then go back to doing it a little bit at a time. I was wondering if I should be worried about this or is it just a normal function with my case.
Sounds like the HDD LED. Perfectly normal.
