7 minutes ago, xrehborn said:
Can i run a cat5e ethernet cable through a two-way splitter and have a cat6 ethernet cable coming out?
That is not capable to split it unless you use a switch, and it will be limited by the lowest common denominator in the whole setup. You can use a CAt 5e with a CAT6 cable but if you are trying to get 10 gigabit speeds that will not work.
https://linustechtips.com/topic/722687-wiring/#findComment-9198494
