Have you looked into monitors and other peripherals? Are you going to upgrade those too?
SLI/CrossFireX setups do exhibit microstutter issues at times which is annoying. Plus you have to wait for SLI profiles when new games come out, or you'll drop down the performance of a single card until you get them. SLI can be a bit of a headache which is one of the things that makes the Titan valuable to some; it can be beat in raw performance by SLI cards at a bit of a lower price, but with the Titan you get consistently high performance while SLI performance can be all over the place, sometimes higher and sometimes lower, depending on how the games are optimized. In some games, 4-way SLI actually performs worse than a single card.
https://linustechtips.com/topic/7223-computer-project-help/page/2/#findComment-78126
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: Intel Core i7-3770K 3.5GHz Quad-Core Processor ($229.99 @ Microcenter)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($109.07 @ NCIX US)
Motherboard: MSI Z77 MPOWER ATX LGA1155 Motherboard ($197.98 @ SuperBiiz)
Memory: Corsair Vengeance Performance 32GB (4 x 8GB) DDR3-1866 Memory ($219.99 @ Newegg)
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive ($89.99 @ Microcenter)
Storage: Samsung 840 Pro Series 128GB 2.5" Solid State Disk ($137.63 @ Amazon)
Video Card: MSI GeForce GTX 680 2GB Video Card ($504.13 @ SuperBiiz)
Case: Corsair C70 Gunmetal Black (Black) ATX Mid Tower Case ($128.98 @ Newegg)
Power Supply: XFX ProSeries 750W 80 PLUS Gold Certified ATX12V / EPS12V Power Supply ($119.99 @ Newegg)
Total: $2007.72
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-03-17 21:07 EDT-0400)
All great stuff from great manufacteurers.
The case is place holder (for price reference, but it is a good case).
The PSU is awesome, OEM Seasonic-X (top of the line). Has enough juice for SLI 680s or 7970s.
A 680 if you can use the Cuda for GPU acceleration in the video editing, if not, I would go with a 7970 Lightning.
Didn't know if you already have the four drives for raid, but I recommend WD Caviar Blacks if not.
Oh only because i don't want to upgrade soon I'm looking for a GPU that will stay in the tops for a while, I'm soon going in an apartment and i will not have the cash anymore so thats why i was looking for putting down 1k on The GPU or GPU's
Sorry i did not mean to say that the GTX 680 was not good in any way it just dos not fit my longterm needs :)
https://linustechtips.com/topic/7223-computer-project-help/page/2/#findComment-78409
Total: $2007.72
I don't quite get your logic.. Perhaps because there is none. Why do you want to spend 1000 Dollars on Graphics Cards? Forgive me for saying this, and I'm not meaning to be rude but, you're coming of as an immature child. Don't hate, that's just my opinion. I've come across many people like you before who have a lot of cash and want to just wave it about. You can get a more than enough of a decent PC for $1500 which will do what you wan just as well.
If a 650Ti can play any current game on high with reasonable FPS and will do for a little while what do you expect to happen in the next couple of years that will put a 680 out of the leader boards? The only single GPU better than a 680 is a Titan, and maybe a 7970.
Gaming = GPU
Video editing = CPU/RAM.
But hey, doesn't matter right :)
Intel i7 3770k
SLI 670/680 / Crossfire 7870/7950 (AMD will be cheaper but since your Bill Gates's son what does that extra matter)
Mushkin Redline / Corsair Dominator Platinum 32GB (1866)
ASRock X79 / Asus Rampage IV
Enough storage to suit your needs
Corsair Neutron GTX SSD's
Corsair AX 1000W
Anything else that's needed I'm sure you can choose for yourself considering you know how to build a PC.
https://linustechtips.com/topic/7223-computer-project-help/page/2/#findComment-78501
Total: $2007.72
Hey calm down dude I value your help thats why im hear.
and i dont know how to build a pc or esle i would not be asking for help
I dont like saying this but the reason i need a rig that will last a long time is because i have the money only now.
i decided to pay my self a treat because i just finish my chemotherapy! on a computer because i am pasionate about them
I will never have this kind of money again that is why i want the best
stop hatting if you do not want to help me you do not have to
https://linustechtips.com/topic/7223-computer-project-help/page/2/#findComment-78788
thanks for the advise i think this made me chamge my mind on sli cards
Thank you to mister windspeed for de PSU advice
i was wondering what was a good price for a modular power supplie responding to my needs
170 $ ?? is that too much because the HX750 looks good and seams like the cheapest modular power supplie
https://linustechtips.com/topic/7223-computer-project-help/page/2/#findComment-78791
Total: $2007.72
Just ignore him... his advice is sort of lobsided anyway :/ To the OP, buying the best of the best components usually isn't worth it. Rather than buy a GTX Titan for $1000 and get some decent performance increase over a $500 GTX 680, when the GTX 680 pretty much is sufficient for any current games, it's a better idea to just save the extra $500 for later and spend it on the newest best card a few years down the road when the GTX 680 is outdated.
https://linustechtips.com/topic/7223-computer-project-help/page/2/#findComment-78806
Total: $2007.72
ok so your saying for double the price you wont really get double the performence
you are right i could keep that money for later upgrades
https://linustechtips.com/topic/7223-computer-project-help/page/2/#findComment-78811
Total: $2007.72
Yes. There's a certain optimum price point where you reach the best balance. In the lower range, a $100 graphics card will usually perform 4x as well or more than a $50 graphics card... that eventually swings the other way though, $1000 video cards perform less than twice as well as $500 ones. Usually any of the more "mainstream" cards has the best value; $200-$500 cards.
https://linustechtips.com/topic/7223-computer-project-help/page/2/#findComment-78814
Total: $2007.72
do you think starting with one and adding a second one later would be a good solution ?
https://linustechtips.com/topic/7223-computer-project-help/page/2/#findComment-78815
Total: $2007.72
Yeah you could do that. Usually I'd only recommend SLI if you need more power than you can get with a single card (triple monitors for example). As an upgrade path, it's a better idea when the time comes to upgrade to just sell the card and get the newest top card, which will usually perform as well or nearly as well, and since you'll have a single GPU all the time you can save money upfront on a lower wattage power supply.
https://linustechtips.com/topic/7223-computer-project-help/page/2/#findComment-78824
With a high budget and heavy video editing in mind, I'd say go for an X79 platform, with the i7-3930K with a H100i or H220 and maybe the GIGABYTE GA-X79-UP4 for a motherboard, with two GTX 680s in SLI. For the power supply I'd probably go with a SeaSonic Platinum SS-760XP and put it all in a Corsair Obsidian 650D case.
I agree, The extra threads would really help.
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
https://linustechtips.com/topic/7223-computer-project-help/page/2/#findComment-78833
Total: $2007.72
Great thanks allot man this will be very helpfull
https://linustechtips.com/topic/7223-computer-project-help/page/2/#findComment-78845
