Pics could help. Did you paint the fans btw? Also maybe some paint has dripped on the PCB or have you forgot a internal wire?
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
Well thank-you for the quick response, however I seem to have fixed it by disassembling and reassembling. No I just painted the shroud as paint on fans can affect performance.
Its not so much that it affects performance, but the extra weight from the paint can slow the fans down, making the bearings have to work harder = wear out quicker. And it would be very hard to get an even coverage on each fin, so if one is heavier than the other, it may not cause it to be level when it spins, and hit the heatsink or shroud :P
Aye henche why I asked because he mentioned that sound.
Anyway glad it is solved and looks good.
PSU Tier list
