3 minutes ago, pappsz said:
Try to install the driver for the network adapter, use the driver disk they sent you, or if you want the latest download it from another computer
ive been tring to look for it, and the ones ive downloaded idk how to install the driver since the folder comes with alot of things
https://linustechtips.com/topic/721757-win-7-help-with-laptop/#findComment-9187688
http://dlcdnet.asus.com/pub/ASUS/nb/X75A/LAN_Atheros_Win7_64_Z201516.zip?_ga=1.82109334.1800130127.1483463284
Put the folder this links to on a USB drive. Move it to the laptop.
Use windows explorere to extract it to a folder on your desktop
Open the folder
Run setup.exe from the folder.
Follow the prompts and restart.
proffit
i7 4930k \ Asus P9X79 LE \ Corsair H100i \ 16 GB DDR3 G.SKILL Ripjaw \ Asus Strix R9 380x 4GB \ Crucial 500 GB Sata III SSD \ Thermaltake TR2 RX 850W \ Corsair Crystal 460 Black \ Razer Naga Molten edition \ Razer Black Widow Ultimate \ Klipsch Promedia 2.1 speakers \ Hyper X Cloud Alpha \
i5 6600k\ Asus Z170-A \ Corsair H100i v2 \ 16 GB DDR4 G.SKILL Ripjaw \ Asus GTX 1060 6GB 4GB \ SanDisk 480 GB Sata III SSD \ Seasonic G Series550W \ DIYPC Skyline 06 black/green \ Razer Naga Epic \ Razer Black Widow Chroma \ Logitech 2.1 Speakers \ Logitech G430 \
https://linustechtips.com/topic/721757-win-7-help-with-laptop/#findComment-9187737
