I'm looking at liquid cooling my GPU- since I live in Australia, summer temps get very hot and this negatively impacts my 1070. My PC is very quiet in winter when the GPU fan speeds remain under 30% but with the summer heat it can get very loud. I'm looking at getting a NZXT G10 bracket but now I just need an AIO liquid cooler. Don't want to get anything too expensive; just something that's quiet and does the job- I've had bad experiences in the past with Corsair AIO pumps so am steering clear from them. Any suggestions would be appreciated.
https://linustechtips.com/topic/721723-quiet-aio-gpu-liquid-cooling/
I'd go with an NZXT kraken x41, although it's priced kind of bullshit for a single rad AiO.
Considering the fact that NZXT created the G10, so they'd obviously make sure it's compatible with their own products. If you want to look into other AiO's then only thing I can think of is google to find ones compatible with the G10.
Just found this here, http://support.nzxt.com/hc/en-us/articles/202479944-What-is-the-G10-compatible-with-
Going off that I'd probably recommend the Corsair H55. which is only $60 and is good. although don't know how much it would cost for ya
