Hi, I built this pc:
NZXT 850w hale 90v2
Asus Z170-A
Gskill 2x4 2800
Intel I7 6700K
Evga 1070 FTW Hybrid
WD Black 1TB
Samsung 950 pro 256gb (Primary)
So I decide to update from W7 Ultimate to W10 pro and the problems started, it's a weird error.
My mobo have an Autodiagnostic tool, when something is wrong a led blinks. Sometimes when I turn on my pc it freezes in the Asus screen, and the boot device led blinks, but if I wait 10/15s it starts normally. This doesn't happened to me when I had W7. How can I fix this or is normal ?
I'm worried for my ssd, when I used my WD Black like a primary disk with W10 it damaged the disk.
I hate W10 have a loot of troubles but some good things, I don't know if I should back to W7.
Thanks You!
https://linustechtips.com/topic/721368-weird-problem-with-ssd/
Your SSD is fine. Your HDD is giving alerts that some sectors are dying and it does indicate a possible upcoming slowdown or even death. Do backups.
And upgrading from older Windows to 10 has shown many issues. Format C, install clean Windows 10 and most of these issues are solved.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/721368-weird-problem-with-ssd/#findComment-9183163
1 minute ago, jj9987 said:
Your SSD is fine. Your HDD is giving alerts that some sectors are dying and it does indicate a possible upcoming death. Do backups.
Oh great then, I'll try to format the C and install clean W10.
Many thanks!
https://linustechtips.com/topic/721368-weird-problem-with-ssd/#findComment-9183175
