Lag without power adapter
Go to solution Solved by Coombzy,
So basically i cant do anything about it?
nope it can't power the gpu without the adapter unlike a standard laptop power brick the ones with dedicated graphics have more watts to be able to power the gpu inside the machine and if it can't receive the watts it downclocks everything.
When i remove my power adapter from my laptop, games lag for a few seconds, and then smooths out.
The gpu monitor shows that it is using my 660m.
Whats the fix.
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/72121-lag-without-power-adapter/
Leave it plugged in. All laptops go into a power saving state when on battery power.
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/72121-lag-without-power-adapter/#findComment-987513
You could force high-performance mode .
Yeah it does not even switch modes!
https://linustechtips.com/topic/72121-lag-without-power-adapter/#findComment-987541
it will probably have switched to the integrated graphics or downclocked the cpu and gpu to save power (cant actually power the gpu on battery thats what the power adapter is for) thats what most gaming laptops do best to keep them plugged in at all times.
https://linustechtips.com/topic/72121-lag-without-power-adapter/#findComment-987553
*ding ding ding* We have a winner!
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/72121-lag-without-power-adapter/#findComment-987567
https://linustechtips.com/topic/72121-lag-without-power-adapter/#findComment-987577
https://linustechtips.com/topic/72121-lag-without-power-adapter/#findComment-987589
