I'm thinking about getting three 120x120x25 PC case fans that will plug into my motherboard. Do PWM fans work similar to the fans on my EVGA 970 GTX whereby the hotter the GPU gets the faster the fans spin in order to cool down the component? Also if it's a PWM fan does that mean it has a 4-pin connector?
https://linustechtips.com/topic/721189-pwm-case-fans/
1 minute ago, Droidbot said:
they're called 120mm fans. they are controlled by the motherboard and they will spin up when the temperature in the case gets higher.
I'm looking for 4-pin case fans right that plug into my motherboard for them to be PWM fans?
https://linustechtips.com/topic/721189-pwm-case-fans/#findComment-9181315
yes, the 4pin case fans are PWM. the difference between 4 and 3 pin is one signal line that allows control of the fan speed by controlling voltage
idk
https://linustechtips.com/topic/721189-pwm-case-fans/#findComment-9181318
PWM (pulse width modulation) is just a way to deliver power. As opposed to DC which varies voltage for different fans speeds, PWM pulses 12v at different intervals to vary fan speed.
Either can be controlled just as easily and how each header on the motherboard acts varies depending on the board.
Yes, 4pin fans are generally pwm.
If you would like fan recommendations, list your specs and explain why you're looking to get new fans.
https://linustechtips.com/topic/721189-pwm-case-fans/#findComment-9181323
Only if you use software to tell them to do that. You can tell 3-pin fans to change speed too, using a program called Speedfan.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/721189-pwm-case-fans/#findComment-9181342
So even if my motherboard has three four pin slots for plugging case fans into I still need software to control the fan speeds?
https://linustechtips.com/topic/721189-pwm-case-fans/#findComment-9181433
4pin fan headers may be wired differently depending on the motherboard and the default fan setting on each header will vary as well.
It seems that you're new to the topic and it might help to list your specs and explain why you're looking to get new fans.
https://linustechtips.com/topic/721189-pwm-case-fans/#findComment-9181442
Depending on the model, you may be able to control them through your BIOS as well
Computer Specs:
https://linustechtips.com/topic/721189-pwm-case-fans/#findComment-9181443
Oh god I'm gonna have nightmares about this.
Computer Specs:
https://linustechtips.com/topic/721189-pwm-case-fans/#findComment-9181445
Boo
zVRM9.pngn5OgzUj.pngattachment.php?attachmentid=145721&d=14016287d1330775095-help-chassis-power-fan-
https://linustechtips.com/topic/721189-pwm-case-fans/#findComment-9181448
2 minutes ago, WoodenMarker said:
Boo
  Reveal hidden contents
Alright that's it. I'm not sleeping tonight.
Computer Specs:
https://linustechtips.com/topic/721189-pwm-case-fans/#findComment-9181452
I'm using a  Asus Maximus VII Ranger Intel Z97 motherboard which comes with three four pin connectors for system fans. How do I check how the pins are wired?
https://linustechtips.com/topic/721189-pwm-case-fans/#findComment-9181619
You can find it in the motherboard manual which is on the manufacturer's website.
https://linustechtips.com/topic/721189-pwm-case-fans/#findComment-9181760
