I have a Seagate FreeAgent GoFlex 1TB external hard drive that used to work perfectly fine, but a few days ago, it started to not work properly. It can be ejected, but it is not found in file explorer.
I opened disk management (diskmgmt.msc) but it shows it as unallocated and only shows 3.86GB of space. If I right click the box, the options for New Simple Volume, New Spanned Volume, and New Striped Volume are all grayed out and cannot be selected. My question is, is there any way to make the hard drive work properly without having to reformat it? I really need to recover the files inside the hard drive. Any help is much appreciated. Thank you!
https://linustechtips.com/topic/720607-recover-data-from-external-hard-drive/
4 minutes ago, FirstClass said:
snip
The exact same thing happened to me with my older Seagate external drive. I tried everything but none of it worked so I ended up shelling out a hundred or so for drive recovery by a data recovery store.
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
I really hope there's a solution without having to pay more than a hundred dollars just to recover my data...
I personally couldn't find one but hopefully there should be.
Desktop
LAPTOP
You could try run Chkdsk, here is a tutorial for win7 that should work in later versions http://www.sevenforums.com/tutorials/433-disk-check.html
you could do a smart test for physical failures but i dont think its physical failure.
heres a bunch of tools on technet relating to disk management that are alternatives that show disk partitions https://technet.microsoft.com/en-us/sysinternals/bb545046
interesting ones are NTFSinfo, and DiskExt
ψ ︿_____︿_ψ_
