Im looking for a lighting object that thumps to bass. Whether its o physical bass or bass on my computer. I go to LANs and they play music, so I want my case to go with their music. If i cant switch it back and forth between my computer and the physical bass, I would like it to be physical bass. I once had this but it was a LED cathode tube made for underbody of a car and it burned out some of my stuff. (once upon a time)
single bay/dual bay controller would be amazing, and multicolor would also be amazing.
Corsair 800D Case      NZXT Hue      NZXT Sentry-001LX     EVGA Gold Standard 850W PSU     Corsair Vengeance LED 32GB PC4 C15 DDR4 3000MHz     i5 7600k @ 4.2GHz     Gigabyte GA-Z270 ATX Gaming K3     8 Fans     Titan X     1.5TB Internal SSD
Corsair K70 RGB Keyboard     Logitech G602     Bose QC15 Headphones     c910 Logitech Webcam(used for microphone also)     (3) 27" LG Monitors     Bose Companion 2 Series III Speakers     Logitech Gamepad F310  Oculus Rift Tri-Cams
CLICK HERE TO SEE MY BUILD (not updated)
https://linustechtips.com/topic/7206-inside-lighting-help/
You can try this. You connect CCFLs to it: http://www.pccasegear.com/index.php?main_page=product_info&cPath=1354_1356&products_id=17481
I used to have one. It's not the best solution but its not bad. I think you can get ones that respond to an audio output rather than actual sound but I've only heard of them, never seen one.
https://linustechtips.com/topic/7206-inside-lighting-help/#findComment-76706
thanks for the idea, the rest of that site is pretty cool - i wanna get that 3.5 inch bay controller for the sound instead of the one u said because it mounts to the outside of the case.
https://linustechtips.com/topic/7206-inside-lighting-help/#findComment-77541
