I'm doing a full build for my B-I-L and I'm not sure what to get him. I was thinking a 6600-k but idk if that is too much card for him. His budget is around $1000 +or- and he wants to be able to play titles such as Far Cry and Tomb Raider. The whole build revolves around the CPU and GPU. Seeing as I already got him a GTX980sc second hand where should I start?
https://linustechtips.com/topic/720284-building-for-a-friend/
$1,000 in what? USD? CND? AUD? Probably won't need to spend near $1,000. Do you have any other parts other than the GTX 980?
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/720284-building-for-a-friend/#findComment-9170285
7 minutes ago, Kris_Kid said:
I would go with a i5 6500 16gb of ddr4 memory a 600w power supply 500gb ssd and a 1tb hdd a case that you like and as for your mobo find the cheapest one you can in the form factor you like I would ask consider a decent cooler like the cryorig c1
i5-6500 will not even let him upgrade his GPU, 980 is at 1060's performance level and a 1070 will already be bottlenecked in some games, let alone a 1080 and GPUs get more and more powerful with every generation, I'd go for an i7 with such budget.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/720284-building-for-a-friend/#findComment-9170318
In most games an i5 Will not bottleneck a 1070 only in the most cpu intensive games will it bottleneck a 1070 plus an i7 isn't nessasary for gaming
https://linustechtips.com/topic/720284-building-for-a-friend/#findComment-9170389
You need to understand that yeah, while it will be "enough" for a 1070 in most games, his next GPU upgrade after a 980 will inevitably be faster than a 1070 if he upgrades in let's say two years, if he does that then he'll have to upgrade the CPU as well cause it won't be able to keep up with the GPU. I still stand by an i7 cause it will last longer than just 1 GPU upgrade.
https://linustechtips.com/topic/720284-building-for-a-friend/#findComment-9170399
I like this point you make, if I do upgrade from the 980 I will go to a 1080 or above.
https://linustechtips.com/topic/720284-building-for-a-friend/#findComment-9170406
This should fit your 1000$ budget assuming that the 980 costs 200$ as you said:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($328.99 @ SuperBiiz)
CPU Cooler: Corsair H100i v2 70.7 CFM Liquid CPU Cooler  ($96.99 @ Jet)
Motherboard: ASRock Z170 Pro4 ATX LGA1151 Motherboard  ($99.99 @ SuperBiiz)
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB) DDR4-3000 Memory  ($84.97 @ Jet)
Storage: Kingston SSDNow UV400 120GB 2.5" Solid State Drive  ($45.49 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.75 @ SuperBiiz)
Case: Phanteks ECLIPSE P400 ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($54.89 @ B&H)
Total: $821.06
Generated by PCPartPicker 2017-01-09 10:05 EST-0500
https://linustechtips.com/topic/720284-building-for-a-friend/#findComment-9170419
Total: $821.06
Thank You!
https://linustechtips.com/topic/720284-building-for-a-friend/#findComment-9170450
