evga thermal pads
Go to solution Solved by Narnash,
33 minutes ago, jamogeto said:
hey is ther a way to get the evga thermal pads i live in kenya (in africa) i bought a 1070.went to the evga website but they dont ship to my country
Do you need new thermal pads for your 1070? If yes search in forums (ask here maybe to) for the thickness of the thermal pads for your specific evga card. You could also write or call the EVGA support dirctly and ask for the thermal pad thickness.
Than you can buy aftermarket thermal pads which would even likly perform better than the stock EVGA ones.
PS: Arctic's thermal pads are cheap but performed at least as good as any other original thermal pad I used in the past. But you can also search fo comparisons online ofc.
https://linustechtips.com/topic/720214-evga-thermal-pads/#findComment-9169749
