Here is my current build plan. https://pcpartpicker.com/list/fTt76X I need to add a CPU (Intel only), motherboard, and CPU cooler (liquid or air) to it, with a 500$ budget. I plan on using this primarily for gaming and will be doing some light overclocking.
Sidenote: If any of you have recommendations for a good 100-200 gaming monitor, 25 inch, 60 hz, 1-2 ms response time, that would be great.
https://linustechtips.com/topic/720094-need-help-finished-build-plan/
37 minutes ago, xxxHellcatsxxx said:
You didn't actually say what your other components were using and you didn't say you needed RAM so based on that here is what I would do:
Processor
Cooler
Motherboard
Thanks for pointing that out. I added the link.
In addition to the requested part recommendations I would suggest a few changes to the OP build list.
A slightly less expensive memory kit with the same performance from a reputable manufacturer.
A much larger ssd. A larger, fast store will provide a better experience than the smaller but faster ssd.
A much better psu.
CPU: Intel Core i5-7600K 3.8GHz Quad-Core Processor  ($242.89 @ B&H)
CPU Cooler: Corsair H100i v2 70.7 CFM Liquid CPU Cooler  ($96.99 @ Jet)
Motherboard: Asus PRIME Z270-P ATX LGA1151 Motherboard  ($135.00 @ B&H)
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB) DDR4-3000 Memory  ($84.97 @ Jet)
Storage: Crucial MX300 275GB 2.5" Solid State Drive  ($83.29 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.78 @ OutletPC)
Video Card: Sapphire Radeon RX 480 8GB NITRO+ OC Video Card  ($267.99 @ Jet)
Case: NZXT S340 (White) ATX Mid Tower Case  ($66.99 @ SuperBiiz)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($64.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($90.72 @ B&H)
Wireless Network Adapter: Gigabyte GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($29.99 @ Newegg Marketplace)
Total: $1213.60
Generated by PCPartPicker 2017-01-09 01:16 EST-0500
A much better psu.
Total: $1213.60
I might be using CableMod to color some of my cables, at least the 24 pin and 6 pin. Do you have another recommendation for a fully modular PSU?
EVGA SuperNOVA 550 (220-G2-0550-Y1) would be an excellent choice. As would  Corsair RM550x.
I couldn't find any ddr4, 3000mhz or faster, white 2x8 gb memory for a reasonable price. I changed the powersupply to the one you suggested, plus 100 watts, and upgraded the ssd from 128 to 256 gbs. Here is the new list. Any final things? I plan to begin purhcasing parts within the next few days.
New List
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($145.03 @ Amazon)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($93.99 @ Jet)
Storage: Intel 600p Series 128GB M.2-2280 Solid State Drive  ($52.97 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.69 @ OutletPC)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.99 @ Jet)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($85.99 @ Amazon)
Total: $1207.51
Generated by PCPartPicker 2017-01-09 18:20 EST-0500
New List
Looks fine. I would note that the Intel 600p is not the best performing NVMe drive.
1 minute ago, ParzivalFX said:
I just wanted my computer to boot as fast as possible. I wanted an upgrade from my current 3 minute boot time. Other than the SSD, do you think that the build is done and I can start purchasing?
A SATA III ssd will give you very good boot times. The 600p will be faster.
Build list looks good to me.
