I am trying my  hand at custom water cooling and I think I have a fairly good grasp on what I'm going to be doing. I will be cooling a 4770k overclocked to 4.6 ghz and SLI GTX 780's. For a case i'm running the Corsair 900D and will have a quadruple 120mm rad in the bottom of the case, and then a simple single 120 up top. Will this be enough cooling capacity? Or will I benefit from more radiators? My understanding was that the quad 120 mm should be enough, so I just threw the single 120 at it for good measure.
Open to suggestions though!
Thanks
4770k@4.7Ghz--Asus Sabertooth Z87--(2)GTX SC 780 (SLI)--Corsair Vengeance 16GB--Corsiar 860i--Samsung SSD 128GB X 2--Corsair 900d--Custom Water Cooled
https://linustechtips.com/topic/71998-will-i-have-enough-rads/
-> owns 900d
-> puts 2 rads in
dude, there so much spaaaace. Fill it all up already.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/71998-will-i-have-enough-rads/#findComment-985871
I will be enough but you have a 900D... Get your self 2x 480's, 1x 360, 1x 240 and one 140
My Pc: Cpu: I7 4790k @ 4,8 Ghz @1,25 volts, Motherboard: Maximus VII Formula, Graphicscard: 2x Titan X @1,4 at stock voltage (soon to be replaced), Ram: 32 gb Corsair Dominator Platinum 2133 Cl 9, SSD: 2x 850 Pro 1 Tb in Raid 0, 2x Samsung 840 Evo 1 tb raid 1,, PSU: Corsair HXi Series 1000W 80+ Platinum, Case: H440. Soon to be watercooled again, maybe, probably, the Titans are too loud.
https://linustechtips.com/topic/71998-will-i-have-enough-rads/#findComment-985903
You have the best watercooling case ever, fill that thing up with rads.
CPU: Intel Core i7-4790k @ 4.7 1.3v  with a Corsair H80 w/Dual SP120s - Motherboard: MSI Z97 gaming 5 - RAM: 4x4 G.Skill Ripjaws X @ 1600 - GPU: Dual PowerColour R9 290- SSD: Samsung NVME SM951 256GB-- PSU: Corsair RM 1000  - Case: NZXT H440 Black/red - Keyboard: Coolermaster CM storm Quickfire TK, Cherry MX blues - Mouse: Logitech G502 - Heaphones: Beyerdynamic DT 770 - Monitors: 3x VE248H Eyefinity 1080P -  Phone: iPhone 6S Plus               Please post your specifications in your post, signature or even better, system page on your profile!
https://linustechtips.com/topic/71998-will-i-have-enough-rads/#findComment-985917
Oh, I know, there's loads of space in this case. I bought it so I wouldn't need to upgrade the case for a long time. I also read that an excessive amount of rads won't necessarily help. It gets to a point where it's as cool as it's going to be, so more doesn't necessarily help. I guess I'm curious if adding another rad will actually help, or if it will (with my current setup) be a waste of money?
https://linustechtips.com/topic/71998-will-i-have-enough-rads/#findComment-986452
I am going to go ahead and add a triple 120 as well. My next question would be, do the radiators come with plugs for the ports that I dont use, or do I need to buy those too?
https://linustechtips.com/topic/71998-will-i-have-enough-rads/#findComment-986566
Generally speaking they do come with enough plugs. There will be enough plugs for all but two of the holes in the radiator since you will be needing those two for in and out.
https://linustechtips.com/topic/71998-will-i-have-enough-rads/#findComment-987092
Yes.
Gaming System: i7 3770k @4.6GHz, Gigabyte Z77X-UD5H, 8GB Corsair 1600MHz, 2 x MSI GTX 670 PE, Fractal R4, 256GB Crucial M4, Fractal Newton R3 1000W White
Steam Box: Xeon E3 1280 @ 3.5GHz, Intel S1200KP, 8GB Corsair White LP, 1x EVGA GTX 570, Fractal Node 304 White, 64GB Intel SSD, Fractal Tesla R2 650w White
https://linustechtips.com/topic/71998-will-i-have-enough-rads/#findComment-987414
