Case: Cooler Master 410 Elite
O.S: Windows 7
Motherboard: Gigabyte B75M-D3H
CPU: Intel i5-2320 @ 3.00GHz
Power Supply: Hytec 750w
SDD: SanDisk 120GG25
HDD: Western Digital 10EARX 1TB
RAM: G.Skill RIPJAWS 8GBXL
GPU: Galaxy GTX560 Slim
CPU Cooler: Cooler Master Hyper 212 Plus
Fan Cooling: 5x Cooler Master Blue LED, 1x T.B.A Pollish blue LED Twister Bearing
at the moment i have a GTX560 and planning to upgrade in the future to a 700 series(when it comes out). what else would need to be upgraded?
For gaming, programming and mass multitasking
Motherboard: Gigabyte B75M-D3H                 CPU: Intel i5-2320 @ 3.00GHz   SDD: SanDisk 120GG25                    Power Supply: Hytec 750w
CPU Cooler: Cooler Master Hyper 212 Plus  GPU: Galaxy GTX560 Slim           RAM: G.Skill RIPJAWS 8GBXL          HDD: Western Digital 10EARX 1TB
Case: Cooler Master 410 Elite                          O.S: Windows 7 Ultimate            Fan Cooling: 5x Cooler Master Blue LED, 1x T.B.Pollish Blue LED
https://linustechtips.com/topic/7199-pc-upgrade-help/
someone help?
https://linustechtips.com/topic/7199-pc-upgrade-help/#findComment-76651
Hopefully under $1000
https://linustechtips.com/topic/7199-pc-upgrade-help/#findComment-76672
So you're wanting a semi-decent all-round PC upgrade for under $1000? I've got dinner in a second, give me a couple minutes and I'll give you a list of parts. (Is that your current PC in the description?)
P.S, with NVIDIA recently releasing the Titan, you'll be waiting a long time for the release of GTX 700 GPU's. And depending on what you'll be doing with your computer in the future, and just going by simple logic that 700 Series GPU's will be better than 600 Series GPU's, you wouldn't even need one. And they'd probably be very expensive.
Gaming is purely reliant on the GPU, as for mass multitasking and programming, CPU/RAM. But you'll want a better Motherboard to support those, like an ASRock Z77.
Edit: Ok so upgrades. I take it everything in your list is what you already have? If that's the case, not much has to be changed really. And being British I don't really know how much prices are for you, so I'm just going of general knowledge.
I would say go with an i5-3330 or 3570k but being British most of the US Tech sites take forever to load, and I can't seem to find either on Newegg. So for now, that 2320 is fine. It's going to be a pain, but swap out that case for a Corsair 200r/300r. Motherboard is good, B75 are your basic Boards and don't allow overclocking, so if that's what you'll be doing don't swap it. If you will be overclocking, Z77 Boards.
There's no way you need a 750W PSU, I don't even have that in my i5-3570k/680 build. Switch it for a Corsair CX 600W. Or Corsair TX 650W. Definitely get a different SSD. Intel 330 Series SSD's can't really be beaten for what they offer. Reliable, perform well, and quite cheap. I would say switch RAM makes to Corsair Vengeance but, since you won't be switching Motherboard's, and depending on your building skills you shouldn't have to take everything apart, I'd stick with that RAM.
As for cooling.. Why on Earth would you want 5x Fans!? Whenever I'm helping someone with a build they always want extra Fans, but with most decent cases you don't really need them as there's already sufficient airflow, and most cases have at least 2 built-in Fans. Time for that GPU.. Again it all depends on what games you'll play, and your setup. Based on the assumption that you'll play games like Call of Duty, Halo, Battlefield and stuff like that, a GTX 650Ti/660/660Ti will do perfectly. Like I said, since you're wanting a good all-round PC there's lots of things you have to focus on. So if you take into the account the changes I listed earlier, and depending on your left-over budget, a 2GB 650 Ti will still play on high settings and maintain good smooth FPS.
https://linustechtips.com/topic/7199-pc-upgrade-help/#findComment-76842
Thanx for the help, lol maybe I should remove some fans :)
https://linustechtips.com/topic/7199-pc-upgrade-help/#findComment-76903
Why would he swap out components that have little or nothing to do with overall performance and currently work fine?
https://linustechtips.com/topic/7199-pc-upgrade-help/#findComment-76972
