Hi Guys,
I'm looking for 120-140mm Green LED case fans to purchase on the cheap.
Looking for the Cheapest possible.
Thanks in Advance.
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
Gigabyte RX 5600XT OC 6GB
-STORAGE-
1x Western Digital 1TB HDD
1x Samsung M.2 1TB SSD
1x Crucial 275GB MX300 SSD
-RAM-
Team Group 2 x 8GB DDR4 2400mHZ
-PSU-
Corsair CX-M Series CX650M
-MOBO-
Gigabyte Z170X-Gaming 6
-CASE-
Phanteks P400S Satin Black TG Edition
-PERIPHERALS-
Logitech g502 RGB and Blackwidow Elite.
-PART PICKER URL-
https://au.pcpartpicker.com/list/Jf9tbj
Have a Nice Day, Give us a Thumbs up if I helped you, Why Not?
https://linustechtips.com/topic/719502-what-fans/
You lost me when you included "looking for" and "LED" in the same sentence, I knew there were 12 year-olds on the forum but come on...
jk but I found some. They're £5 in the UK so I thought they'd be something reasonable in Australia too but they're $14 http://www.skycomp.com.au/coolermaster-sickleflow-x-120mm-case-fan-green-led.html
Then there are these for $9 http://www.newegg.com/global/au/Product/Product.aspx?Item=N82E16835345013&nm_mc=AFC-C8Junction-AU&cm_mmc=AFC-C8Junction-AU-_-Case Fans-_-BitFenix Co. Ltd.-_-35345013&cm_sp=&AID=11892377&PID=3938566&SID=
Which are literally the cheapest I found. I'd imagine shipping would be an issue though.
https://linustechtips.com/topic/719502-what-fans/#findComment-9162158
I looked around for the Coolermaster sickleflow , and found them for 8 AUD.
http://cplonline.com.au/coolers/case-fan/coolermaster-120mm-sickleflow-x-green-led-r4-sxdp-20fg-a1.html
Thanks for the help.
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
-STORAGE-
-RAM-
-PSU-
-MOBO-
-CASE-
-PERIPHERALS-
-PART PICKER URL-
https://linustechtips.com/topic/719502-what-fans/#findComment-9162183
Perfect, no problem!
https://linustechtips.com/topic/719502-what-fans/#findComment-9162187
Hi Guys,
I was looking for a fan controller to fit into a  5.25" bay.
Looking for it to have graphics for around 50AUD.
Thanks in advacne.
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
-STORAGE-
-RAM-
-PSU-
-MOBO-
-CASE-
-PERIPHERALS-
-PART PICKER URL-
https://linustechtips.com/topic/719502-what-fans/#findComment-9163731
9 hours ago, KillerGamingBro said:
Hi Guys,
Thanks in advacne.
What fans are you trying to control and why are you looking for a 5.25" bay controller in particular?
https://linustechtips.com/topic/719502-what-fans/#findComment-9166303
10 hours ago, wONKEyeYEs said:
You have 3 system fan headers each of which can run two fans.
I have an Asus and an MSI MB and custom fan profiles can be set in BIOS and software.
Why do you need a fan controller?
How can they run two off each?
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
-STORAGE-
-RAM-
-PSU-
-MOBO-
-CASE-
-PERIPHERALS-
-PART PICKER URL-
https://linustechtips.com/topic/719502-what-fans/#findComment-9166431
i like the look and i want more than 3 fans.
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
-STORAGE-
-RAM-
-PSU-
-MOBO-
-CASE-
-PERIPHERALS-
-PART PICKER URL-
https://linustechtips.com/topic/719502-what-fans/#findComment-9166433
https://linustechtips.com/topic/719502-what-fans/#findComment-9166447
1 minute ago, WoodenMarker said:
Thanks, I will probably go that route instead,
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
-STORAGE-
-RAM-
-PSU-
-MOBO-
-CASE-
-PERIPHERALS-
-PART PICKER URL-
https://linustechtips.com/topic/719502-what-fans/#findComment-9166454
