Need help acquiring CPU cooler.
Solved by iRileyx,
The Noctua NH-L line may be good for you to look at.
This one for example, only 37mm tall with the fan.
https://www.overclockers.co.uk/noctua-nh-l9i-cpu-cooler-low-profile-92mm-hs-024-nc.html?gclid=Cj0KEQiAwMLDBRDCh_r9sMvQ_88BEiQA6zuAQ9CzY85MJZ_AACBSo5BdiLS_VRfkQFdGk0EHqtM5L4UaAobz8P8HAQ
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
