HI guys, wondering if you think the Gelid wing 12 120mm PWM blue led fan is any good for use with a slim radiator specifically the bitspower 240mm slim one.
Ive already got the corsair SP120 rgb for the front 360mm rad so should i go with the same fans or just go Gelid because its cheaper, with removable impeller so easier cleaning and under volts well?
https://linustechtips.com/topic/718980-fans-for-radiator/
2 minutes ago, tronder said:
ah i see, any recommendations for other SP fans?
you dont have to get RGB fans.. you can get their normal SP series fans to.  2 for $26 USD. A pretty good price. These are what I would go with if I wasnt using Noctua or EK Vardar.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181025&cm_re=SP120-_-35-181-025-_-Product
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/718980-fans-for-radiator/#findComment-9157561
Noctua NF-F12, Fractal Venturi HP-12, EK Vardar,
5 minutes ago, Romeo Bodmon said:
No, from a quick glance they look like they are airflow fans, not static pressure fans (thats what "SP" stands for in SP120)
You want static pressure fans for radiators. So if those are your two options then yes go with the SP120s
Honestly they look like fine fans for pressure. It's not as straightforward as thick blade = pressure, look at EK Vardars for instance
It's best to look at their performance.
http://www.coolingtechnique.com/recensioni/air-cooling/ventole/414-recensione-gelid-wing-12.html?start=2
They're actually not too bad for 1500RPM fans, compared to the NF-F12 they're lower performance though.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/718980-fans-for-radiator/#findComment-9157569
The way the fins look makes me think SP but the gap between the fan and the casing draws a red flag to me. Yeah performance is pretty decent to what I would have expected. But defiantly go for the better preforming fans. Or if anything the 2 SP120s will do a deace job for cheap af.
https://linustechtips.com/topic/718980-fans-for-radiator/#findComment-9157580
I'm just gonna leave this here and say that as long as you don't cheap out, and do your research you should be fine (also, pwm fans are amazing)
https://linustechtips.com/topic/718980-fans-for-radiator/#findComment-9157598
17 minutes ago, tronder said:
are EK Vardar fans that good?
EK Vardar are great fans, and very quiet.. rival my Noctua for the quietest.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/718980-fans-for-radiator/#findComment-9157616
35 minutes ago, tronder said:
Which do you think EK Varder or Corsair ML 120? im looking for PWN and silence?
I'd probably say the Corsair ML; they both seem to have PWM versions, but the in my experience EK Varder is more about performance over sound, while the MLs are more about having the quietest motor possible with great performance still
The MLs will definitely be more expensive though
(I will almost always be partial to Noctua fans, they make some good shit)
https://linustechtips.com/topic/718980-fans-for-radiator/#findComment-9160594
