I currently have more peripherals than my computer allows (eg. Xbox controller adapter, wifi dongle, etc) and was wondering if buying a 7-port usb hub would be a good idea, and if it would have enough bandwidth to run (and power) a keyboard, mouse, headset, wifi dongle and xbox adapter.
Any help is appreciated.
Thanks,
Coldris
https://linustechtips.com/topic/718974-usb-hub-questions/
Thanks,
Coldris
You would be limited by the single USB port I would recommend to have the USB wifi and such devices dedicated to a USB port on the board only for that device and have the others on the hub. You can get power USB hub however if you have heavier power draw devices.
https://linustechtips.com/topic/718974-usb-hub-questions/#findComment-9157508
