Bootstrap and Grunt installation.
Solved by mrchow19910319,
8 hours ago, AMTraxTGE said:
I am using bootstrap locally now... I thought I have to install all that to use bootstrap, turns out all I need was include some links in my html file, then it works...
I think that set it all up for a local workflow is too complicated for me... So.. Thanks for your input!
