Hi folks,
I've gone through lots of videos of how to build a pc especially the ones of linustechtips. But I'm still doubtful abt the parts I'm to buy for my pc.
I'm looking for a 4k gaming and would prefer one with the gtx 1080 if it's any good than the lower versions of Nvidia graphic cards (I would gladly accept suggestions of other cards to the gtx 1080 if they can accomplish my needs as well as the 1080 can or more), I'm looking for an Intel processor, most likely the new kaby Lake i7 processor  and I would like suggestions for the motherboard compatible with the kaby Lake i7 processor, I would like suggestions to the cooling fans and power supply as I'm not very strong in that area and the hard drive and ssd for the pc and finally I would like to know what cases will be compatible with these parts. I'm confused with the case the most as I'm not sure which is enough for these parts and I'm not sure if all the parts will fit into the case if I'm to look into one.
Oh and finally my budget is around 2000 USD
Just some questions that I would like to clear :
* What's the use of a heat sync?
* Is a cooler necessary for the processor?
* what type of cooling is the most practical and best?
I appreciate any help in advance. Thank you .
https://linustechtips.com/topic/718407-help-me-build-a-pc/
Divert hear away from critical components (RAM, CPU, GPU) to cooling solutions
Definitely
The most practical ist air cooling, but there is no single "best" solution. It depends on what you are trying to achieve
75% of what I say is sarcastic
So is the rest probably
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151078
A heatsink is used to draw heat away from the processor.
Yeah, unless you're looking to fry eggs on yours.
Most practical is an air cooler, for best performance water cooling *usually* is best.
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151087
Liquid Nitrogen. Clearly the most practical and best. xD
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
Gigabyte RX 5600XT OC 6GB
-STORAGE-
1x Western Digital 1TB HDD
1x Samsung M.2 1TB SSD
1x Crucial 275GB MX300 SSD
-RAM-
Team Group 2 x 8GB DDR4 2400mHZ
-PSU-
Corsair CX-M Series CX650M
-MOBO-
Gigabyte Z170X-Gaming 6
-CASE-
Phanteks P400S Satin Black TG Edition
-PERIPHERALS-
Logitech g502 RGB and Blackwidow Elite.
-PART PICKER URL-
https://au.pcpartpicker.com/list/Jf9tbj
Have a Nice Day, Give us a Thumbs up if I helped you, Why Not?
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151092
ez, no room for failure there
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151093
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($328.99 @ SuperBiiz) margin of error performance difference between kabylake and skylake, just get whichever is cheaper.
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.99 @ Newegg Marketplace) absolutely necessary, no exceptions.
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard  ($111.98 @ Newegg)
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB) DDR4-3000 Memory  ($84.97 @ Jet)
Storage: PNY CS1311 240GB 2.5" Solid State Drive  ($64.99 @ Jet)
Storage: Toshiba 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ OutletPC)
Case: DIYPC G580-BK ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: BitFenix Fury 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($78.99 @ SuperBiiz)
Other: Nvidia GTX Titan X Pascal ($1200.00)
Total: $2001.79
Generated by PCPartPicker 2017-01-06 05:15 EST-0500
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151097
Total: $2001.79
I'm pretty sure the titan x is preferred more for graphic work and not gaming may be wrong but he would be better if with a 1080 and maybe a 1080 in sli the sli part I don't know much about so that would require research
PC Build
Ryzen 1800x
Asus Strix 1080ti
G-Skill Trident z RGB 32gb 3200mhz
Gigabyte K7 motherboard
NZXT Kraken x62
EVGA Supernova P2 850w
Phanteks Enthoo Evolv ATX TG
SAMSUNG 960 EVO M.2 1tb
Seagate Barracuda 3tb
Gigabyte WiFi and Bluetooth Card
x3 NZXT Aer RGB Fans
NZXT Hue
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151112
Not worth it to invest into Kaby Lake over Skylake unless you have the mindset where you need the latest and greatest. $20 for practically zero performance gain isn't worth it.
Here's a build with two GTX 1080s for 4K Ultra gaming. Either that or get a Titan XP and watercool it with a bracket and an AIO liquid cooler.
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($93.99 @ Jet)
Storage: ADATA Premier SP550 240GB 2.5" Solid State Drive  ($68.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.78 @ OutletPC)
Video Card: Zotac GeForce GTX 1080 8GB AMP! Edition Video Card (2-Way SLI)  ($580.66 @ B&H)
Case: Fractal Design Define S w/Window ATX Mid Tower Case  ($79.99 @ Newegg)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($75.79 @ OutletPC)
Total: $2005.82
Generated by PCPartPicker 2017-01-06 05:20 EST-0500
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151117
It might be better to just wait for the 1080 TI
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151118
picked it over gtx 1080 SLI to prevent the issues what would happen with SLI.
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151119
I assume you mean heat sink
http://www.wisefull.com.img.800cdn.com/images/200906/1245827348092913436.jpg
These pick up the heat from the processor and because of their huge surface area, lets fans blow away the heat a little (lot) better than just blowing straight on the processor.
As for the cooler of the processor.
These are the difference between underclocking your 2550k to 2.8GHz on the stock cooler vs running it on 5.0GHz on a Cooler Master Hyper 212 EVO.
Without one, don't expect to get further than the bios though, without maybe shortening the CPU_FAN pins, in which case you might get to see your windows wallpaper before it throttles thermally down to zero until it shuts off.
Most practical and best, custom loop watercooling. Costs the same as an old car.
Value for cash? The Cooler Master Hyper 212 EVO, 40$ and you're golden.
Nothing impressive, one of the most popular fans on the market though.
Excuse my broken keyboard
CPU - Ryzen 7 2700x
GPU - RX Vega 64
SSD - Samsung 970 M.2 500GB
HDD - WD Black 4TB
Mobo - Asus ROG Strix X470-F Gaming
RAM - 32GB Corsair Vengeance DDR4
PSU - Corsair RM1000x
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151121
Yeah, popular but not that popular anymore I hope. You can get better for the same price.  hopefully you don't mean 40$ usd, that would be a scam.
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151130
Total: $2001.79
good lawd what is that PSU, for the same price you could get a G2
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151134
BitFenix Fury 750w :P seems fine, tier 3 in the psu tier list(and braided :o)
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151135
No you're thinking of the quadros. Titan XP is actually meant for gaming as absurd as it sounds.
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151136
yeah but edited
I'd get a T1 PSU if you plan on spending so much on a PC already.
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151137
Computer parts are so much more expensive here compared to newegg and amazon :(
Even Amazon UK constantly undercuts by like 20%, but buying from there is an extreme hassle.
CPU - Ryzen 7 2700x
GPU - RX Vega 64
HDD - WD Black 4TB
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151142
2 minutes ago, Megah3rtz said:
yeah but edited
eh, wanted to have more room for SLI in the future.
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151143
yeeaah ha . 42$ is almost double what it should be. I bought mine onsale for 15$ usd.
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151147
30 minutes ago, Blakjak97 said:
Hi folks,
https://pcpartpicker.com/list/BTxDnn The cooler and the case is up to you. If you don't need 6 cores, you might want to go for the 7700k. Also, it would be a good idea to wait for the 1080 TI. I will be about 25 percent faster
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151155
$41.15 for the 212 for us, guess we're on the same boat:(
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151156
Also, the best cooling (except custom water loops (500 USD+) is about 100 USD. H115i from Corsair is nice, but if it is out of your budget right now you can always but a 212 EVO and upgrade the cooling if you need it down the road.
https://linustechtips.com/topic/718407-help-me-build-a-pc/#findComment-9151162
