Virtual Monitor
Elardoven
I'm not sure if this is possible, but I wanted to ask you all. I'd like to know if I can input video and audio from something like a PS4 into my computer and run it into a window on my computer. Any ideas?
My Build: i7-4790K, 212 Evo, Asus Maximus VI Extreme, Crucial Ballistix Sport 16GB DDR3-1600, Intel 730 240GB SSD, WD Blue 1TB, EVGA GTX 980Ti ACX 2.0, NZXT H440 Blue/Black, EVGA 650W 80+Gold.
Most of the time, it's not the computer, it's the person using it.
@Wolther I'm trying to do that so I can share audio between my computer and console for discord/music, and be able to swap between the console/computer easily without having to change inputs.
Gotcha
what inputs do you have on your monitor? If you're have HDMI x2 then just connect your sound system to the headphone socket then just switch inputs on the monitor.
I can see using a capture card causing input lag.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
@vorticalbox How would I combine the audio then?
Gamer oriented capture devices are good at minimizing lag so it's not bad, if you can even perceive it.
You can't. If you wanted to combine audio streams, you would need a capture device or use the PS4 streaming app.
