If you wan something more high-end, you could use something like https://tenonedesign.com/mountie.php. It's a clip to attach devices together. You dont have to buy that model, but some item like that would work.
Oh? Well hello there! Notice me please!
        Specs!
CPU: A AMD A10 APU
HDD: like, 1 terabyte
RAM: 2x4 gig sticks of kingston DDR3
GPU: heheh- the amd A10 APU with radeon graphics oh wow
PSU: What ever is inside this thing
MOBO: same thing as the psu
Hah. this is my laptop. spooked.
https://linustechtips.com/topic/718016-i-need-help/#findComment-9146630
4 minutes ago, VeeTeePee said:
The best solution to this is the same as a lot of other things... It's sad how much this useful thing is overlooked. Smh
<SNIP>
That time I saved Linus' WiFi pass from appearing on YouTube:
A sudden Linus re-appears : http://linustechtips.com/main/topic/390793-important-dailymotion-account-still-active/
https://linustechtips.com/topic/718016-i-need-help/#findComment-9146631
Im looking for something compatible with cases it wouldnt work very well.
https://linustechtips.com/topic/718016-i-need-help/#findComment-9146649
Like i said, there are probably other types of clamps like this that are bigger.
        Specs!
CPU: A AMD A10 APU
https://linustechtips.com/topic/718016-i-need-help/#findComment-9146667
1 minute ago, obi-fade-kenobi said:
So get two cheap phone cases and pop them in and out as required lmao?
For a good 3 bucks on ebay
        Specs!
CPU: A AMD A10 APU
https://linustechtips.com/topic/718016-i-need-help/#findComment-9146675
