Most likly this, they shouldn't had changed that by the time from model to model (btw you should get rif of these OEM stuff for your own PC but when you are on budget ) pluging it wrong shouldn't result in any damage, it just wouldn't start ( or show the in case you pluged LED's wron only)
https://linustechtips.com/topic/716726-pin-layout/#findComment-9132038
1 minute ago, Narnash said:
Most likly this, they shouldn't change that from model to model (btw you should get rif of these OEM stuff for your own PC but when you are on budget )
I  bought an old acer machine  bcuz  it had an i7  and now I am transferring it to a new case(760T)  next upgrade Ryzen (if it's worth  it)
https://linustechtips.com/topic/716726-pin-layout/#findComment-9132043
Sure my body just needed to clarify that OEM mobos are junk. -_-
EDIT: I like to play with junk sometimes
https://linustechtips.com/topic/716726-pin-layout/#findComment-9132076
4 minutes ago, Scitesh said:
Thanks man  it could have destroyed my pc  experience
First I was like, "that is some kind of LED power connector stuff" than I saw D- and D+ and remembered that the old USB 2 ones looked like these ... I used one last time I paired my pump on my old build (can be controlled via usb)
https://linustechtips.com/topic/716726-pin-layout/#findComment-9132388
