Hey I've a problem with my computer it doesn't turns on when I press the power button but when I take out the power cable out of the power supply then plug it back in 5 or 6 times it turns on for a second the fans start spinning then turns off but if I quickly plug the power cable back in when its turns on for a second then the pc  turns on just fine  after that if I turn it off and turn it on it turns on just fine but if I turn off my pc for a few hours then try turning it on  same problem occurs , I've tried another power cable but same result , Do yall think its fault in power supply? I bought it year ago & it was second hand
My specs are
4th gen Corei5 4440 3.1ghz
2x8 ( 16gb)  1600mhz ddr3 Corsair vengeance
1tb Segate barcuda 7200rpm
240gb Corsair LE SSD  (SATA III)
Gigabyte GTX 1060 6gb windforce 2x
Gigabyte H81 mobo
Creative 7.1 sound card
Seasonic 80+ bronze  500watts psu ( SS-500ET)
Corsair Carbide 200R casing with three Corsair 120mm  AF fans plus one 140mm Xigamatech fan
https://linustechtips.com/topic/716682-pc-turning-on-problem/
It does sound like a PSU fault. Do you have a spare PSU you can test to confirm it is the PSU?
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
Gigabyte RX 5600XT OC 6GB
-STORAGE-
1x Western Digital 1TB HDD
1x Samsung M.2 1TB SSD
1x Crucial 275GB MX300 SSD
-RAM-
Team Group 2 x 8GB DDR4 2400mHZ
-PSU-
Corsair CX-M Series CX650M
-MOBO-
Gigabyte Z170X-Gaming 6
-CASE-
Phanteks P400S Satin Black TG Edition
-PERIPHERALS-
Logitech g502 RGB and Blackwidow Elite.
-PART PICKER URL-
https://au.pcpartpicker.com/list/Jf9tbj
Have a Nice Day, Give us a Thumbs up if I helped you, Why Not?
https://linustechtips.com/topic/716682-pc-turning-on-problem/#findComment-9131541
No I don't , Should I take it out & try testing it with a paper clip? & if its fault in the power supply do you suggest repairing it or replacing it  cause where I am from repairing is cheap asf
https://linustechtips.com/topic/716682-pc-turning-on-problem/#findComment-9131565
Try testing it with the paperclip. Have you had the PSU repaired before? If you have multiple times its probably time to replace it, but if it's the first time you've had a fault,  get it repaired. You can get fairly decent PSU's for not too much online if you look in the right places.
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
-STORAGE-
-RAM-
-PSU-
-MOBO-
-CASE-
-PERIPHERALS-
-PART PICKER URL-
https://linustechtips.com/topic/716682-pc-turning-on-problem/#findComment-9131578
No I have never gotten it repaired  although the warranty seal on it was already broken meaning somebody opened it before  & people only open PSUs when there is a fault since its second hand / used I don't know its previous history  , All my friends told me its best to replace the psu  other then repairing  it cause  things break down when their life is over , I found an ad on Olx of a person selling Cooler master G750M  for a reasonable price  & hes from my city should I get that psu? my friend told me its a tier 3 psu its not that good  but not bad either but since I don't overclock or do SLI/Crossfire do you think I should be fine?
https://linustechtips.com/topic/716682-pc-turning-on-problem/#findComment-9131627
It's not a bad PSU, just check it has enough wattage for your build on a PSU calculator. If it's a reasonable price compared to other prices you have seen, go for it.
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
-STORAGE-
-RAM-
-PSU-
-MOBO-
-CASE-
-PERIPHERALS-
-PART PICKER URL-
https://linustechtips.com/topic/716682-pc-turning-on-problem/#findComment-9131635
I've replaced it with Seasonic 620watts 80+bronze M12II & my pc works now :D so it was the psu's fault after all , by the way  is it possible to use another psu's modular cable with another modular psu? because  my friend has Silverstone 750watts ( SST-ST75F) & he has 1x6 & 1x6+2  but the specs on  the official site says it has 4x6 pin connectors so I asked him how he end up with 1x6 & 1x6+2  he said cause cables are missing & hes using a different psu's modular cable
https://linustechtips.com/topic/716682-pc-turning-on-problem/#findComment-9170423
You should be able to,  just do a quick google search before trying.
Also, Good to hear that your PC is working again.
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
-STORAGE-
-RAM-
-PSU-
-MOBO-
-CASE-
-PERIPHERALS-
-PART PICKER URL-
https://linustechtips.com/topic/716682-pc-turning-on-problem/#findComment-9172124
Yep its possible cause I used another psu's molex modular cable on my psu and it worked , a friend of mine told me its not good to use  a different psu's modular cable on a different psu saying it can damage the psu  but I think that would only happen if the voltage of the cables was different than the orginal cable only reason I needed molex connector was cause I use my fans off it via a 3pin to molex adapter   , fans don't require a lot of power so I should be good & as far as for my old psu I got it fixed too I might keep it or sell it :D
https://linustechtips.com/topic/716682-pc-turning-on-problem/#findComment-9194747
Cool, good luck in future builds! :)
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
-STORAGE-
-RAM-
-PSU-
-MOBO-
-CASE-
-PERIPHERALS-
-PART PICKER URL-
https://linustechtips.com/topic/716682-pc-turning-on-problem/#findComment-9196319
