I need some help finding some projects for my arduino uno. Just to make it slightly easier for typing stuff in, here is a link to the kit i have so u can see the parts:
https://www.sunfounder.com/learn/category/From-Knowing-To-Utilizing-Kit-V2-0-for-Arduino.html
I didnt know if I should put this here or in Hobby Electronics, but if u r a mod, just move it.
-Piero
i like trains 🙂
https://linustechtips.com/topic/716507-arduino-projects/
I also find it a little hard to build projects for the Arduino, a lot of times you just have to buy hardware specific to your ideas instead of trying to come up with ideas based off of hardware. But with what you have the most potential I find is with the photoresistor and the relay. The photoresistor is a great input because it can be used for a large variety of factors. Not only can you use it as a single analog input but you could also pretend like it is a digital input and use it like a switch and it doesn't even require touch. This allows for the possibility of projects that use a kind of motion detection off very simple hardware. And if you have multiple of these you could even do some simple gesture detection. The relay is my favorite output because you can easily control electronics outside of your Arduino circuitry. My personal favorite 120v power from you wall outlets. With this you could use various input devices to control anything you would normally plug in in your house from your lights to a complex media system.
Hope this helped inspire you a bit.
https://linustechtips.com/topic/716507-arduino-projects/#findComment-9130458
Have any extra floppy drives?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/716507-arduino-projects/#findComment-9130673
The link you gave has 21 projects from basic to intermediate that will show you alot of the world of microcontrollers. Maybe you should start there, since those projects are built around the parts in your kit. After that, you'll be able to more easily come up with ideas that interest you.
ENCRYPTION IS NOT A CRIME
https://linustechtips.com/topic/716507-arduino-projects/#findComment-9134180
I made a more accurate temperature sensor off of the lm35 detector. Thanks
i like trains 🙂
https://linustechtips.com/topic/716507-arduino-projects/#findComment-9142571
